How do I repair/replace the 7960 Stand Lock?
dave.wiggins
The stand no longer holds the phone upright.  I can hear that something is loose.  How do I remove the stand?  (without breaking it)
Kelly Dodd
To remove it, turn the phone over, lay down the stand and then locate the 2 tabs on the stand chassis.  The tabs are located at the "bottom" of the stand (the narrow part of the stand) and you use a medium flat blade screwdriver to push them back.  They are located about a quater inch from each end.
Kelly,
Perfect. Thank you. I didn't notice those little slide tabs there.
Sincerely,
Dave Wiggins
Government agencies can now subscribe to DocuVantage OnDemand using Apps.Gov!
Interested in News and Information from DocuVantage? Sign up Here
