How do I reset a 7921 WiFi phone to factory default settings
I am unable to reset the 7921g phone to factory settings can anyone help?
Hall of Fame Super Red
Re: How do I reset a 7921 WiFi phone to factory default settings
Hi PPD,
I believe the sequence is;
Settings> Phone settings> Press **2, it will display "start factory reset now"> Select Yes
Hope this helps!
Rob
yep that works! many thanks.
Hi PPD,
You are most welcome my friend!
Cheers!
Rob
thanks !
thanks !
this  is also  useful  for me  to  reset  wifi phone 7925
10019
