How do I stop sending Display info to my provider
I have a site with CallManager 4.1 using MGCP on a PRI gateway. The provider is complaining that we are sending to much information in the setup and connection phase. How can I disable/stop CallManager from sending this information?
From debug isdn q931:
Display i = 'Voicemail'
1 REPLY
Re: How do I stop sending Display info to my provider
uncheck display IE delivery under the endpoint config
java
if this helps, please rate
java
www.cisco.com/go/pdi
128
