How do I test the "SA" and "DC Directory" passwords?
I am adding a new subscriber to a Call Manager 4.2(3) Cluster, and during the setup, I have to enter the passwords for the following...
- SA (SQL Server system administrator) password
- Directory Manager (DC Directory) password
- Private Password Phrase for the Cluster
I have a password for each one, and I think it is correct, but I have no way to know for sure.
Is there somewhere I can go on the Publisher or on any of the existing Subscribers to test the password that I have for each of these three?
David
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: How do I test the "SA" and "DC Directory" passwords?
Hi David,
I would just go ahead and use the ones that you have. If there is a problem the install will let you know and you can use the tool shown below to re-sync the passwords;
This tool should only be used during Off-Production Hours.
From this excellent Tech Note;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080557ba5.shtml
Also check out;
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K96486351
Cheers!
Rob
Hi David,
Also check out;
Cheers!
Rob
Thank you very much Rob.
From your links, I also found a click through to this link: http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K20914488
It covers the SA account, which is very handy.
Thanks again!
David
123
