How Do I tie a dial-peer to a specific FXO Port
Hello Voice Experts,
Here is the scenario : we have multiple analog lines and each one is connected to a FXO port and we want to tie some fax machines (Connected Via ATAs) to these analog lines. The ATAs are registered with the CUCM and I have configured the gateway as a H323 gateway. Route-patterns are configured on the CUCM and dial-peers are configured also on the gateway. My problem is when a fax machines ( 411xx90) sends an outgoing fax , it goes out from the wrong FXO port as 441xx77. I know this happens because we have multiple outgoing dial-peers with the same destination-pattern but to different FXO ports. How do I fix this ?
I tried MGCP and it worked great but I faced this problem where the call counter started to count even when the other phone was on-Hook and ringing.
I googled this problem and found this document from Cisco ""FXO Disconnect Problem". I tried the solutions from Cisco but nothing worked
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t2/feature/guide/ft_ansds.html
That's why I am trying with H323. Any suggestions would be appreciated.
Mohamed Gazzaz
CCIE Security #25719
1 ACCEPTED SOLUTION
Re: How Do I tie a dial-peer to a specific FXO Port
Hi Mmohammed,
in order to bind a specific extension to a specific FXO port you need to do the following:
voice translation-rule 1
rule 1 /^/ /19/
note: "19" can be any number which you will reference later in the dial peer
voice-port 0/0/0
connection plar opx 5400
description direct line 45366665
caller-id enable
dial-peer voice 200 voip
translation-profile incoming Test
answer-address 5400
dial-peer voice 19 pots
destination-pattern 19T
port 0/0/0
you have to create the above for every direct line.
i hope this will work with you. For me i tested and it is working good.
regards,
Ibrahim Chehouri
voice translation-profile Test
translate called 1
Try to use "preference" option under dial-peer configuration.
When you have multiple outgoing dial-peers matched at same time the "preference" command specifies the metching order.
The highest priority is given to the dial peer with preference order 0 and it is the default value. You can have a preference value between 0 to 10.
dial-peer voice 100 pots
preference 1       --- Make this the first choice dial peer.
ip precedence 5
destination-pattern 1...
port 1/0/0
dial-peer voice 101 pots
preference 2       --- This  is the second choice.
ip precedence 5
 port 1/0/1
Thanks, but this is not what I want. I want for example
Fax machine connected to a ATA and has a Directory Number of 4410290.
                         DN= 4410290                                               analog line connected to the PSTN and has the number of 4410290
Fax machine 1<--> ATA 1 <---> CUCM <--> H323 Gateway  <--> FXO port 1 <--> PSTN
                         DN= 4410277                                               analog line connected to the PSTN and has the number of 4410277
Fax machine 2 <--> ATA 2 <---> CUCM <--> H323 Gateway  <--> FXO port 2 <--> PSTN
Sometimes when Fax1 sends an outgoing fax, it goes out from FXO Port 2 which has the wrong number. How do I make outgoing faxes from Fax 1 always go out from FXO port 1 ?
Hi Mmohammed,
rule 1 /^/ /19/
voice-port 0/0/0
caller-id enable
answer-address 5400
port 0/0/0
regards,
Ibrahim Chehouri
translate called 1
Hi Ibrahim,
Thank you very much. It worked like a charm.
Mohamed Gazzaz
750
