How do you block inbound calls from a number?
I am using Unified CM 6.1.x. How do I block an inbound call from a specific phone number?
Thanks.
Re: How do you block inbound calls from a number?
You can refer to one of the thousands of posts with the exact same question that exist in NetPro
IP Telephony: Blocking incoming numbers on voice gateway CUCM 5
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd4043c
I'm just posting one but there are way too many post for this same question, PLEASE try searching NetPro for answers.
java
if this helps, please rate
java
www.cisco.com/go/pdi
I already saw this. I was looking for a way to do it with MGCP but it looks like there is no way. I hope Cisco will add that in a future update.
Thanks.
For MGCP I normally use a translation pattern that matches on the calling number and translates the called number to a CTI Route Point configured to forward all calls to a Unity Mailbox with a greeting stating something like "Unsolicited calls are not welcome"
Bronze
How are you routing on the the calling number?
408
