How do you decipher facility codes on Q931 traces
I have an issue on site with divert messages across a qsig link. The customer is diverting calls from an sx2000 pabx to callmanager via a MGCP gateway. I need to understand the facility codes and how to decipher them ?
Green
Re: How do you decipher facility codes on Q931 traces
hi in my debug isdn q931 i have the following message, what do i paste into the decode tool
Facility i = 0x9FAA068001008201008B0100A1190202017B06052B0C024E01300C8004303030300A0102040144
Green
Could you please paste the whole debug isdn q931. This encoder looks like is not recognizing:
9F AA 06 80 01 00 82 01 00 8B 01 00 A1 19 02 02 01 7B 06 05 2B 0C 02 4E 01 30 0C 80 04 30 30 30 30 0A 01 02 04 01 44
hi the full decode
*Jul 17 15:13:56.102: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00B6
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9FAA068001008201008B0100A1100202018B020100300780055350415245
Facility i = 0x9FAA068001008201008B0100A1190202018C06052B0C024E01300C8004303030300A010204014A
Calling Party Number i = 0x4980, '3769'
Plan:Private, Type:Subscriber(local)
Called Party Number i = 0x80, '2399'
Plan:Unknown, Type:Unknown
*Jul 17 15:13:56.118: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x80B6
*Jul 17 15:13:56.122: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x80B6
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Jul 17 15:13:56.246: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x80B6
Facility i = 0x9FAA06800100820100A1110201020201028009566F6963656D61696C
Connected Number i = 0x0081, '2399'
*Jul 17 15:13:56.262: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00B6
*Jul 17 15:14:08.734: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x00B6
Cause i = 0x8090 - Normal call clearing
*Jul 17 15:14:08.778: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x80B6
*Jul 17 15:14:08.790: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x00B6
Gold
I've attached the decode of the Setup and Connect message.
Hope this helps
hi this is very good but i was looking for some information on the decode for future ref, did you manage to get the decode tool working?
588
