Community Member
How do you Delete a License in CM 6.1 from the CLI?
I entered a bad license file in CM and I was wondering how I remove it from the system even though it is not doing anything. It is not a big deal but I have seen a TAC engineer go in the CLI and do it before but do not remember the command.
Community Member
Re: How do you Delete a License in CM 6.1 from the CLI?
Nevermind. I figured it out. It was 'file delete license '.
Thanks though!
Hall of Fame Super Red
Hi Bryan,
Here are the details :)
file delete
The file delete command includes the parameters dir tftp and license. The file delete command deletes one or more files.
Command Syntax
file delete
dir tftp directory [detail]
license filename [detail]
Parameters
•dir tftp directory deletes the TFTP directory specified by directory. You cannot enter the wildcard character (*) in directory.
•license filename deletes the license file that is specified by license. You can enter the wildcard character (*) as filename to delete all the license files.
Options
•detail-Displays details
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412067
Hope this helps!
Rob
215
