How do you tell if 'utils dbreplication reset all' completed successfully?
I had 8.5.1.10000-26 of CUCM installed and upgraded to an Unrestricted version of 8.5.1.13900-5.  I later researched that I do not want an Unrestricted version and should have the Restricted instead.  I switched versions back to 10000-26 and it warned me I needed to do a 'utils dbreplication reset all' after the Publisher came back up.  Note:  The Subscriber was never switched over to 13900-5 and remains on the Inactive partition.  We only have the two servers, 1 Pub and 1 Sub.
So how do I tell if this dbreplication reset has completed successfully?  I've issued the following commands and I will paste the output...
admin:utils dbreplication status
-------------------- utils dbreplication status --------------------
Replication status check is now running in background.
Use command 'utils dbreplication runtimestate' to check its progress
The final output will be in file cm/trace/dbl/sdi/ReplicationStatus.2012_01_27_22_50_57.out
Please use "file view activelog cm/trace/dbl/sdi/ReplicationStatus.2012_01_27_22_50_57.out " command to see the output
admin:
and
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Replication status command started at: 2012-01-27-22-50
     Replication status command COMPLETED 530 tables checked out of 530
     No Errors or Mismatches found.
     Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2012_01_27_22_50_57.out' to see the details
DB Version: ccm8_5_1_10000_26
Number of replicated tables: 530
Cluster Detailed View from PUB (2 Servers):
                                PING            REPLICATION     REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES  LOOP?   (RTMT) & details
CCMPUB1 10.14.1.1       0.052   Yes     Connected       0       match   Yes     (2) PUB Setup Completed
ccmsub1 10.14.1.2       0.245   Yes     Connected       0       match   Yes     (2) Setup Completed
admin:
Do I have to dig through the output file to determine success, or can anyone tell me from the command outputs I've pasted above if it was a success?  Once I determine it's successful, I will try and upgrade to the Restricted version of 13900-5.
Thank you.
Rory Schmitz
1 ACCEPTED SOLUTION
Hi Rory,
The below doc would be helpful for you
https://supportforums.cisco.com/docs/DOC-13672
Senthil
Hi Rory,
Senthil
Yes, that is a very well put together document.  Thank you very much for posting it.  I was able to determine that everything is OK and can continue on with my next upgrade.
4093
