How do you turn on 9971's video?
I enabled Video Capabilities and Cisco Camera, and option 'Back USB Port' is enabled by default. But I didn't see 'Cisco Camera' under Applications/Accessories. why?
Now I can make voice phone call between 9971s.
Did I miss some setting there?
  • IP Telephony
2 ACCEPTED SOLUTIONS
My guess is you're not
My guess is you're not delivering enough power to turn on the camera.
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Purple
May be Jaime is right. Please
Please have a look into the link
https://supportforums.cisco.com/discussion/11593986/cisco-9971phone-unified-camera-not-wokring
Can u share output of command show power inline  from switch and show version of switch?
regds,
aman
VIP Purple
Hi, Did  u connect the camera
Did  u connect the camera on USB port?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/9971_9951_8961/8_5/english/admin_guide/9971adm851/9971cam.pdf
Adjusting the Camera Settings
Once you have attached the camera on your phone, you can control the features of the camera.
regds,
aman
I connect the camera on back
I connect the camera on back usb port. I can see the light on when I plug in camera.
java
VIP Purple
regds,
aman
VIP Purple
thanks for the rating. was it
was it related to power or something else.
regds,
aman
It works well after I
It works well after I disabled 'power negotiation'.
thank you very much!
VIP Purple
thanks for update.[+5] to you
thanks for update.
[+5] to you.
regds,
aman
77
