How does Call Manager know when to route a call to another gateway?
I had a PRI fail but the Call Manager still showed the gateway active. How did Call Manager know to reroute the calls to another gateway?
1 ACCEPTED SOLUTION
Re: How does Call Manager know when to route a call to another g
Hi Anthony,
As your gateway is registered with CM as h.323 endpoint thats the reason you are not able to make out whether the t1s are working or not instead of that if it would have been MGCP you would have got that information because in MGCP mode gateway is working as Dumb endpoint.
However in ur case its gud idea to configure route list with multiple options so if one is not available to due to some reasons other will take it over.
Hope this should resolve ur query
Gaurav
hi,
Is it registered as H.323 or MGCP gateway
Its registered as a H.323 gateway
On failure, do you have another gateway in the Route List for the route pattern?
Hall of Fame Super Silver
It's controller by having multiple route groups under a route list, or multiple GWs under route group.
Chris
Hi Anthony,
Gaurav
Thats what it is set up to do but my first report of the issue was that local calls were calling numbers in another state and the main number was getting an all circuits busy message. I spent 15 minutes trouble shooting before I realized that even though the PRI looked fine and was showing active in CCM the calls were being sent out another gateway. I rebooted the router and that solved the issue. I just wish CCM would have showed the PRI was not working correctly.
As was stated earlier, MGCP is not only easier to troubleshoot and manage it is also better a call survivability.
Also, if you do not have a compelling reason to using H.323 gateways (IVR), it may be worth looking into. 12.4(9)T4 IPVOICE works fairly well with 28xx platforms.
274
