Community Member
How get CUCM 9.1x software for initial installation
Hi everyone !
My client has purchased R-CBE6K-K9 Cisco Business Edition 6000-Electronic SW Delivery-Top Level.
So I went to cisco dowload software (http://software.cisco.com/download/release.html?mdfid=284510097&flowid=45900&softwareid=282074295&release=9.1%282%29SU1&relind=AVAILABLE&rellifecycle=&reltype=latest)
I got the ISO file:
UCSInstall_UCOS_9.1.2.11900-12.sgn.iso
Biut when I tried to install on my wmware environment (using proper OVA file) it failed, verifying the donwloaded product this is an Update, and a non-bootable....
As a SW Delivery program , where can I get information about the procedure to follow for getting and download my required software??
Thanks in advanced
Enrique
1 ACCEPTED SOLUTION
Bootable iso is not provided on Cisco.com, only the upgrade iso files are made available. You need to order for bootable media, you can engage your Cisco Account team to help.
Manish
Manish
Community Member
You are right.....I haven't had access to the email from Cisco explaining edelivery instructions for proper download.
thanks
263
