Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
How I can find the missing CDRs from the current inactive version.
Dear All,
Before two days I have install and Upgrade call manager to 6.1.4.1000-10. Yesterday I have switch version and finish the upgrade.
Does anybody know how I can find the CDR that has been generated the period after the upgrade and before the switch version?
Thanks in advance
Without doing a switch back to the previous version, I very much doubt you can.
In fact, all changes you've made to the system between installing the upgrade and switching versions will have been lost.
GTG
Please rate all helpful posts.
Yes Thanks fro the reply.
Do you know any other way regarding the CDRs ? If there is any other way to retrieve the cdrs logs from the other incative vesrion (partition) via a commands maybe?
All the commands & APIs I've seen for talking to the CUCM DB only work on the active DB. (If you think about it, to access the inactive DB, you'd need to fire up a copy of the DB engine from the inactive partition too. It all gets horribly messy very quickly)
GTG
190
