How I can hide internal number? CUCM 6
Forexample I want to display Unknown message only.
Re: How I can hide internal number? CUCM 6
If you require the calling party number or name service to be restricted when dialing another internal called party, then you will need to configure a specific translation rule which is matched in your calling party's CSS when the outgoing call is made.
Refer to the Translation pattern configuration for Calling Line and Name presetation restriction:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmcfg/b03txpat.html#wpxref97194
Hope this helps.
Allan.
I am speaking about HIDING number, with somethikng like "Unknown". It's not similar that CSS accesses
VIP Super Bronze
You can achieve this by doing the following:
1. Go to the gateway in question, scroll down to "call routing information-outbound calls"
2. Change the "calling party number presentation to Restricted
3. change the Calling party IE number type unknown to Unknown.
Hope this helps
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
please always look at previous posts
Call Display Restrictions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_1/ccmfeat/fshosp.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
2136
