How I can test H323 telephony for 2 sites without using CUCM?
Re: How I can test H323 telephony for 2 sites without using CUCM
I have 2 gateways with FXS ports:
10.1.1.1 and 10.2.1.1
--10.1.1.1----10.1.1.2--
Can somebody provide me config to connect FXS port for each side and make sides been posible to call from GW1 to GW2 and viceverse
Any answer?
Router1:
dial-peer voice x pots
port 0/0/0
destination-patter 1000
dial-peer voice x voip
destination-pattern 1001
session target ipv4:10.0.0.1
Router2:
port 0/0/0
destination-patter 1001
destination-pattern 1000
session target ipv4:10.0.0.2
-nick
Use Dial Peers:
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfpeers.html#wp1261894
Hope it helps, if it does please rate.
Best regards,
- Adrián.
Can you see now this one topology.
As you see we have Cisco 7206 and PIX firewall in the center of it.
Should I do something in the center of this topology? I mean about configuration of Cisco 7206 and PIX or I should config only routers 10.1.1.1 and 10.1.1.2 ?
Thank you in advance
In theory you shouldn't need to configure anything on your firewalls. However, historically speaking, firewalls and voice have had problems working together.
-nick
141
