12-28-2009 01:56 AM - edited 03-15-2019 08:54 PM
How is it possible to increase capacity of transcoder sessions?
Solved! Go to Solution.
12-28-2009 04:25 AM
By installation of additional DSP modules.
12-29-2009 12:49 PM
"webstd.design" is right by saying increasing your dsp resources but if you are simply referring to altering the sessions, you can do that from your router configuration under the dspfarms. The word "Capacity" is pretty broad.
first check the dsp resources " show voice dsp". If you have more, then simply go under your transcoder dspfarm and alter the maximum sessions.
dspfarm profile 10 transcode
maximum sessions 5
no shu
12-28-2009 04:25 AM
12-29-2009 12:49 PM
maximum sessions 5
no shu
12-31-2009 05:25 AM
Additional one question
If I have several routers, is it possible to use them as one entity without installation additional DSP on only one router?
12-31-2009 10:35 AM
No.
12-31-2009 11:56 AM
It depends which codecs are enabled, depending the codec complexity number of sessions increase or decreased, this is associated to the MIPS in DSPs
Take a look at CUCM SRND Media Resources section
