07-02-2013 04:09 AM - edited 03-16-2019 06:10 PM
i am trying to create more than 8 callin numbers on the CUE, a prompt message indicates that the number of ports exceeded.
i did not find any documentation guide that shows the limitation in callin number on the CUE.
i tested it on cue version 7.x and cue version 8.x with same results.
can anyone confirm if the creation of Callin numbers is limited to the maximum number of licensed CTI ports i.e. 8 ports ?
07-02-2013 05:42 AM
There are two limitations, number of licensed port and max number of AAs. Both are detailed in the release notes according to your specific model.
07-02-2013 06:27 PM
This link is the Full CUE specs based on the hardware module, you can check that info here:
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
