How Many Calls can an Inter-Cluster Trunk support?
How many simultaneous calls can an Inter-Cluster Trunk Support?
We have one set up between two CMs and we get intermittent busy signals.
Re: How Many Calls can an Inter-Cluster Trunk support?
do you have locations for CAC on it?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Yes...the location is set to unlimited audio bandwidth. With 2 different Clusters, how does locations factor into it?
usually you set two locations on each cluster, one on which the phones reside and other one for the ICT. this way you control how much BW can be used for calls over the ICT since usually there is a BW restriction on the links (usually a WAN link), if you allow extra calls to go over the ICT they will affect all calls quality.
that's the reason i was asking, if you have locations when you try a call that goes over the allocated BW it would fail
javalenc
java
256
