How many calls can be made with a PVDM2-48 ?
I'm having voice quality issues. During a conversation, a call gets more and more faint going into a metalic sound to the point where you just hang up.
This happens on calls to the PSTN and accross the WAN. The router has a PVDM2-48. How do you calculate how many calls can be made with this PVDM? How do I know if I'm going over the alloted resources?
I did a test and got this. Does it mean I missing something?
Select option : 16
DSP Keepalive Status Display:
DSP 1 is Alive, State: 4, Keepalive Sent: 190395, Skip 321072
DSP 2 is Alive, State: 4, Keepalive Sent: 254779, Skip 256688
DSP 3 is Alive, State: 4, Keepalive Sent: 255733, Skip 255734
DSP 4 Not Exist
Thanks.
Re: How many calls can be made with a PVDM2-48 ?
no, a PVDM2-48 has 3 DSPs
each channel can support a call with G711, so those are 48 calls if you're only using them for media termination.
i recall some bugs causing metalic sound, might be a good idea to upgrade the dsps FW
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks for the response. What about G729 calls? Is it one per channel? What about transcoding? Is it one tracoding resource perchannel?
Hall of Fame Super Red
Hi D.Anthony,
Just to add a note to the good tips from Java (+5 points my friend)
CSCsd90851 Bug Details
One way Robotic and Metallic voice towards PSTN through 2800
Symptom:
Voice calls through a 2800 gateway starts experiencing Robotic and Metallic voice after a few days of operation. When the problem does occur, it happens on all the calls through the gateway.
Condition:
Observed on a 2851 running IOS release 12.4(3a)
Workaround:
A reset of the DSP or a router reload resolves the problem.
Status
Fixed
Severity
3 - moderate
Last Modified
In Last Year
Product
Cisco IOS software
Technology
1st Found-In
12.4(3a)M
Known Affected Versions
Fixed-In
4.4(19)DSP
6.3(5)DSP
7.4(2)DSP
8.4(0)DSP
12.4(11)T
Hope this helps!
Rob
PS:Thanks for the Bug Nick!
260
