How many characters I can set with Speed Dials on 7916 expansion modules
Id like to know, how many characters I can set with Speed Dials on 7916 expansion modules.
I have to define a rule for speed dials description:
- I see that description 15 characters long, could be works well, but it depends on what type of characters is made the word, For examples the character I  or M or W.
Anyone has an idea ?
Chris Deren
I believe 14 characters will show on the module, and if you have more (up to 32) then you will see "...".
HTH,
Chris
