Community Member
How many FAC can CCM5.1 supports ?
Re: How many FAC can CCM5.1 supports ?
AFAIK as with many elements on the CUCM there is no a hard number for the FACs. Usually the only limitation is to keep it manageable and the HDD space since each entry takes a little space in the DB
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
OK,thanks a lot.
113
