How many operators on one console?
Is it possible to have more than 1 operator per attendant console? So that calls coming in can be picked up by either receptionist on the same number? How do you do this? THANKS!
1 ACCEPTED SOLUTION
Re: How many operators on one console?
In the huntgroup you can setup either phone lines of the attendants or user/line combination. I typically use the user/line combination in the huntgroup. Define two Attendant console users say op1 and op2 and say each have a 7960 with 6 lines each. You can setup the huntgroup members to be op1-L1, op2-L1, op1-L2, op2-L2 ..so on and so forth. Calls coming into the Pilot will go to both operators as long as they are logged in via AC and online.
Sankar
PS: please remember to rate posts!
1 REPLY
Sankar
96
