how many time does IP PHONE was rebooted over the day?
webstd.design
How I can collect this info?
Can anybody guide me?
Jaime Valencia
look at the application log
java
if this helps, please rate
java
Can you guide me how I can do this on CUCM 6?
Should I use RTMT? is yes what should I do?
Thank you!
yes, in RTMT you can pull the application logs, it's near the part where you download the traces. i assume you know how to do this.
java
java
Alternatively, you could enable syslog on Call Manager (set logging level to Error to minimize the amount of log message), each time a phone un-register, Call Manager will send a syslog 'Error' message to your syslog server.
