How much Bandwidth does the Lync Vidoe Call use
Jeylinux4Cisco
Hi There,
I just want to know , In a Cisco Unified Communication Environment, How much Bandwidth does the Lync Vidoe Call use? Is it depends on the Codec which we are using and the resolution?
If we are not configuring anything specially for Lync Video and just enabled in our Environment, How much bandwidth is takes/requried per user?
Need this information to find & calculate the Bandwidth in critical site, Thanks!!
With Best Regards,
Bala
vemanyam
Thank you Veera..
With Best Regards,
Bala
Please rate all useful posts
