Community Member
how stop shrink process cdr database in the ccm publisher
Hi to all,
My problem is that i can not Manual Database Purge from the car, all time with the clock thinking.
So i tried to shrink the cdr database because i have cdr.mdf cdr_log.ldf 7gb and 3gb using the sql server enterprise manager but more than 24 hours and still doing it, how can stop it?, and some solution for it?
regards
Alberto
Community Member
Re: how stop shrink process cdr database in the ccm publisher
version of ccm 4.2(1)
Shrink the CDR/CAR Database Size
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008049aab0.shtml#sol3
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Hi javalenc,
i hava that document and tried the solution 2 but in two days still shrinking the database, i want to known how to stop the solution 2 ( the process).
Thanks a lot,
regards
Alberto
407
