How to access CUE GUI on Cisco Router 2911
Dear All,
We are newbie on Cisco IP Telephony solution. Currently we want implement CUCM using 2 MCS7825 and 1 Cisco Router 2911 as voice gateway (with auto attendant feature on Cisco router 2911).
Cisco Router 2911 come with configuration like this
- Cisco2911-V/K9, qty:1
- SL-29-UC-K9, qty:1
- SL-29-IPB-K9, qty:1
- NM-HDV2, qty:1
- VIC2-4FXO, qty:5
- FL-CUE-PORT-2, qty:5
- ISM-SRE-300-K9, qty:1
Cisco Router 2911 come with Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(1)T2.
Note: we still use startup-config that already exist on Cisco Router 2911.
Now we want configure Cisco router 2911 as auto-attendant, but we cannot access Cisco Unity Express (CUE) on Cisco Router 2911.
On show version we see like this
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
   Cisco Unity Express 8.6.1 in slot/sub-slot 0/0
We have question about it, Our question:
- What configuration on Cisco Router 2911 that we need to access CUE  GUI on Cisco Router 2911?
We attach show version, show running-config, show flash, show inventory (Cisco_2911-capture.txt)
We hope you can give us information about it.
Thanks For Your Attention
ronpatel
Level 8
Level 8
Follow below link to configure your ISM module
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_5/install/installsre.html
After that follow below link for CUE configuration
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
