How to activate CUE 8.6 permanent license file
We had  install CUE 8.6 and it is working with Evaluation license, now we upload the permanent license and reload the CUE, but still the permanent license shows not activated and the CUE is working with Evaluation only.
The screen print and sh command are attached, could please let know how to activate the permanent license.
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Bala,
I'm pretty sure this is your issue here
Have a look at the actual command description. You need to list the name of the license feature (high)
that you want to change to "low"
So for example;
license modify priority VMIVR-PORT high or
license modify priority VMIVR-VM-MBX  high
this should list the VMIVR-PORT or VMIVR-VM-MBX "evaluation" license so that you can change it to low
once you re-boot the higher rated permanent licenses should show active/in use
To modify the license priority information, use the license modify priority command in Cisco Unity Express EXEC mode.
license modify priority feature name {high | low}
Syntax Description
high
Sets the license priority level to high.
low
Sets the license priority level to low.
Command Default
None.
Command Modes
Command History
Cisco Unity Express Version
Modification
7.1
This command was introduced.
Usage Guidelines
This  commands enables you to modify the license priority level. This command  lists all the expiring licenses that are available for the specified  feature and you can change the priority level to be the highest for the  selected license.
Examples
The following example shows how to change the license priority level:
se-10-0-0-0# license modify priority TCV-USER  high
Feature: TCV-USER
Index:  1       License type    : Evaluation
Lock type       : Locked
License Count   : 2
License Priority: Low
Are you sure you want to modify priority? (yes/[no]): yes
Note The application will evaluate the changes in the next reboot.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/Command/l_cmds.html#wp1031346
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
Hall of Fame Super Gold
Re: How to activate CUE 8.6 permanent license file
Reload CUE.
Please do not use attchments for simple text.
Hi Bala,
So for example;
Syntax Description
high
low
Command Default
None.
Command Modes
Command History
Modification
7.1
Usage Guidelines
Examples
Feature: TCV-USER
Lock type       : Locked
License Count   : 2
Cheers!
Rob
The Voice Mail box licenses is active, but the VM-ports are in Evaluation mode, please help me how to activate the VMIVR-ports ?
The sh commands as below:
Diners-CUE8-6# sh license status application
voicemail enabled: 4 ports, 4 sessions, 30 mailboxes
ivr disabled, no activated ivr session license available
Diners-CUE8-6# sh software versions
Cisco Unity Express version (8.6.1)
Technical Support: http://www.cisco.com/techsupport Copyright (c)
isco Systems, Inc.
Components:
- CUE Voicemail Language Support version  8.6.1
Diners-CUE8-6#
Diners-CUE8-6# sh license in-use
StoreIndex:  0  Feature: VMIVR-VM-MBX                      Version
        License Type: Permanent
        License State: Active, In Use
        License Count: 30 /30
        License Priority: Medium
StoreIndex:  1  Feature: VMIVR-PORT                        Version
        License Type: Evaluation
            Evaluation total period:  8 weeks  4 days
            Evaluation period left:  1 week   5 days
            Expiry date: Sun Aug 26 13:12:16 2012
        License Count: 60 /4
Diners-CUE8-6#
You need to contact licensing@cisco.com to obtain VMIVR-PORT licenses that come included with a CUE hardware purchase.
Many Thanks, got the Port license for Licensing team.
2041
