Community Member
How to activate VPN-Group feature in CUCM ?
Hi Experts
I am testing one scenario for builtin vpn client on Cisco IP Phones, for this I have to configure VPN-Group & phone-vpn-features in CUCM. I didnt find the option for VPN-Group in advance feature tab in CUCM, i am using CUCM 8.5. We have to activate this service first ? or additonal license need to be purchased for security services on CUCM like this one ?
Awais
This has nothing to do with licensing, are you using the restricted or unrestricted version??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Thank you . It is restricted version. Can we download the unrestricted version for demo purpose ?
Hi Awais,
VPN is only available on CUCM 8.X and onwards. You need the restricted version, to have all Cryptographic features.
There's no Licensing at least on CUCM side for it.
You don't see the VPN option under the advance features menu? Can you elaborate with a screenshot what are you seen?
325
