You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
how to add 8831 phones to cucm 9.0
How to add the 8831 Conference phone to CUCM 9.0.1.
I could not find the device type to add  in my CUCM and no Firmware found .
Please tell me the steps for how to add 8831.
Nithin Louis.
  • IP Telephony
2 ACCEPTED SOLUTIONS
VIP Purple
Hi Louis,
In addition to what Mr. Manish has said[+5], you can also refer the IP phone feature and CUCM device pack compatibility matrix.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
regds,
aman
Re: how to add 8831 phones to cucm 9.0
Hi Nithin,
If you check the latest readme for 9.0
http://www.cisco.com/web/software/282074299/97296/cmterm-devicepack-9_0_1_11013-1_Readme.pdf
It does not have 8831 as an option.
If you check it for 9.1
http://www.cisco.com/web/software/282074299/104182/cmterm-devicepack-9_1_1_21026-1_Readme.pdf
Its there.
So, please upgrade to 9.1 and it will work.
Thanks Aman [+5] for your thoughts as well.
Manish
probably try by uploading device pack for 8831 SIP phone in call manager else upgrade call manger 9.1version.
Thanks.
Hi Manish,
Thanks for your reply.
I am having 9.0.1 cucm version can i install the device package 9.1 for my cucm.As I can see the software Compatibility for the device package 9.1 is cucm version 9.1.or do i need to upgrade to 9.0.1 to 9.1?
Best Regards
Nithin Louis.
An upgrade to 9.1 is recommended as i believe that there are no software updates being planned for 9.0 version now.
Manish
Hi Manish,
Thank you very much for your quick reply.
As I can see in the data sheet for 8831 its supporting the version from 7.1(5), 8.5(1), 8.6(2),9.0, and later.Please find the attached 8831 phone data sheet. Please check Table 1 in page 2 for supported CUMC.
Is it possible without any upgrade to 9.1 ?
Best Regards
Nithin Louis.
Sorry for not attaching the data sheet.Please review the attached file.
VIP Purple
Hi Louis,
regds,
aman
VIP Purple
Hi Louis,
HAd u been using CUICM 7.1(5)/9.1(1)  then, no Device pack is required?
U can check in the link provided by me.
regds,
aman
Hi Nithin,
Its there.
Manish
13686
