How to add an extension module 7916 at UCM 7.1.3
Dear Frends
I need to add a extension module 7916 + 7965 phone at UCM 7.1.3, but when I add the module It does´t not work.
I need to add something to the configuration?, I already check the aux port between  the units.
So I think that the problem isn´t  phisical.
I´ll be waiting you answers
greetings Leandro
Re: How to add an extension module 7916 at UCM 7.1.3
Make sure you're running at least 8.3(5) FW on your phone
You need to provide a clear explanation of what's happening, red buttons? problem on CCMAdmin?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
The Extension Module 7916 is connected to the phone, but do not run.
In the UCM in the phone settings configured Expansion Module Information, but not know if I need something else in the module configuration.
I need something else in configguracion?
please any suggestions
THX
583
