Community Member
how to adding ip phone to sub when pub is down
hi
two cucm are running in network as publisher and subscriber with 7.1.
how can a ip phone will add to sub when there is no pub(dead).
the sub with out pub will be a read only. so please tell me how to over come
thanks.
Everyone's tags (2)
I am sorry but YOU CANT add or remove or make ANY DB changes in that matter.
CUCM runs, in a Informex PUb-Sub(s) enviroment, where replication happen ONLY from pub to sub(s), so if your pub its offline, DB its lock
Please Kudos/rate if this help!
Just to add couple of thing, since i had this issue . as rightly said by Jose you can performed any move  and changes till PUB dead/OOS state.DB will be in lock state you cannot perform any changes into Database.
Even if you try do so add/delete/modifiy on SUB you will get an error.
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Purple
Hi GVK,
in addition to what Jose and Nadeem has said[+5], u can make some changes in existing phones when PUB is down called as User Facing Features[UFF]
https://supportforums.cisco.com/docs/DOC-13672#User_Facing_Features
Below is a list of user facing features that can be updated by the subscriber and therefore updated while the publisher is down.
Call Forward All (CFA)
Message Waiting Indication (MWI)
Privacy Enable/Disable
Do Not Disturb Enable/Disable (DND)
Extension Mobility Login (EM)
Monitor (for future use, currently no updates at the user level)
Hunt Group Logout
Device Mobility
CTI CAPF status for end users and application users
Credential hacking and authentication
regds,
aman
242
