04-30-2009 09:50 AM - edited 03-15-2019 05:45 PM
For the attached topology, I've assigned 347.76 kbps as a total bandwidth including overheads for 4 simultaneous calls, I need to assign high priority bandwidth for ftp traffic. Also I should give suitable priority to the routing protocols. How can i assign priority for it, can someone please guide me, Thanks
04-30-2009 11:23 AM
General: To configure a QoS for the attached topolgy
ccharlebois - Logis - Apr 29, 2009, 6:15am PSTNew Message!
Considering this is your assignment, I believe it's up to you to read through the documentation that has already been linked and put together a solution for yourself. The people here will typically be happy to review whatever you put together, or help if you get stuck on a particular topic or question.
The links for how to do this have already been provided.
start reading here:
Configuring Weighted Fair Queueing
Low Latency Queueing with Priority Percentage Support
java
if this helps, please rate
04-30-2009 12:51 PM
I would do something like this:
class-map voice
match ip dscp ef
class-map match-any sig
match ip dscp af31
match ip dscp cs3
class-map ftp
match protocol ftp
policy-map wan-edge
class voice
priority 348
class signaling
bandwidth perecent 5
class ftp
bandwidth percent ???
class class-default
fair-queue
Put in whatever percent of bandwidth you want for FTP where the ???'s are. Then apply to the interface
interface serial 0/0/0
service-policy output wan-edge
Please rate if this helped.
