How to Assign DID to a user. Who doesnt have a physical phone
Hello Everyone,
I'm Currently Running Cisco Unified CM Administration System version: 8.6.2.21900-5.
Issue :
I'm trying to assign a DID to user who doesn't have a physical  Cisco phone.
Can I do this on CUCM ? if so how ?
Thanks in advance.
Soofi
Hall of Fame Super Silver
Yes, it all depends though on how you dial plan aligns with the DIDs being delivered, and what protocol you are using for GW control, SIP/MGCP/H323.
HTH,
chris
May i know what is the use of that one?
Normally i used to create a directory number by Routing->Dirctory number option in callmanager then I will give forward all to either voice mail or their cell phone.
Prabaharan,
I'm not sure exactly where you are looking. But yes you can do that in callmanager. From Call Routing-->Directory Number and create the new DN.
Call Routing-->Directory Number --> Add New DN.... Finished....
Bronze
Re:How to Assign DID to a user. Who doesnt have a physical phone
Simply!! What you can dial from your calmanager, you can route calls to BY using DID or something else. ,
Sent from Cisco Technical Support Android App
315
