ā08-19-2013 11:42 PM - edited ā03-16-2019 06:57 PM
Dear All
I have around 1000 Existing Users and 1000 cisco phones in CUCM ver 7.5 , My Question how to associate the existing users with extisting phones by BULK , Step by Step if you can ?
thanks and regards
ā08-20-2013 12:08 AM
You can use BAT to do this....in BAT look for update users tab...open the tab and then look for the column device association...
Put your users in the users column and their corresponding devices in the device column...export the file as BAT..go to cucm , import the file...then go to bat, update users and select the file you have imported..
ā08-20-2013 12:13 AM
Dear Aokanlawon
thanks for your reply , do have file or link that showing me step by step the process ?
thanks
ā08-20-2013 12:25 AM
Don't be lazy..I have given you all the steps. In this field you must be willing to go the extra mile, that's how you distinguish yourself from your peers and make yourself proud.
