how to auto register phone using sip/sccp in cucm 7.1.5
hi
i got some 9951 and 894X that i would them to auto register in sip but i got some 79XX that i would like them to auto register in sccp.
at the moment, some register in sip and other in sccp. is there an option to force them to using one or the other?
thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Phones such as 9951 which can
Phones such as 9951 which can only do SIP will always auto register as SIP, for phone such as 79XX that can do either you define the preferred protocol under the enterprise parameters. You cannot define 2 different models that can do both protocols to behave differently.
Chris
1 REPLY
Chris
65
