How to Backup CUCM Configuration
Dears,
Kinldy i have a UCS-C220M3 box using WMWare ESXi 5 installed with CUCM 9.1 that i have an issue that required to re-install the CUCM again. My qurey is that how i can copy the configuartions i did to re-call them back (IP phones devcies, Trunks, Route Calls, and others) kinldy adbvise?
Humam
VIP Purple
You can take the backup of Entire Call Manager DB using DRS tool.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/9_1_1/CUCM_BK_D9A29FAD_00_disaster-recovery-system-cucm-91.pdf
Once u rebuild CUCM ,Call manager  version , other credentials like hostname,IP address , OS administration/security passwords should be same.
regds,
aman
In addition to the useful infromation as usual which Eng.Aman shared with you. Please find the below steps:-
Step 1
-On The Cisco Unified Communications System navigate to the Disaster Recovery System page and proceed to login.
Step 2
-Select the Backup tab
-Select the Backup Device Tab
-Click either "+" sign or the "Add New" button
Step 3
-Enter a name for your Backup device name*
-Select the Network Directory option
-For the Server name Enter the IP address of your sftp server
-For the Path name if everything on your Freesftpd server was left as default use \ otherwise
make the proper changes.
-For the username, use the username of the SFTP user that you just created in FreeFTPd, in my case is test
-For the password, use the password of the user that you have created in FreeFTPd.
-For the number of Backups to store on Network Directory I ussually select 3, but I leave this up to your discretion.
-Select the Save button.
*If everything went well the status alert message should now show Update succesful
Step 4
-Select the Scheduler tab
-Click either the "+" sign or the "Add New" button
Step 5
-For the Schedule Name enter an appropiate name for this operation
-For the Device Name select your newly created Backup Device
-Select the appropriate feature
-Proceed to enter a Backup start Date and time , this will be the date that you want the backup/schedule process to begin/start, also
keep in mind that time that you select here, it will be the time that the backup process will start according to your selections that you
make below.
-Select the Frequency* Basically when do you want to run a backup operation.
Once
Daily
Weekly (Mon, Tue, Web, Thur, Fri, Sat, Sun)
Monthly
-Click The Save Button
-Click the Enable Schedule button to enable this backup schedule, the status message alert will now show Status Enabled.
Please also find the below link
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080ab9fc0.shtml
Thank you
please rate all useful information
372
