Community Member
How to block incoming calls by calling number (MGCP)
I need to block incoming calls based on the calling number. I have found information online about how to do this if your gateway is H.323 already. However, I am using CallManager connected to a gateway using MGCP. Therefore I believe there must be a way to do this in CallManager itself. Does anyone have any clues on how to do this?
Hall of Fame Super Red
Community Member
Re: How to block incoming calls by calling number (MGCP)
Thanks Rob.
You are correct. I just talked to a TAC engineer who confirmed that as well. The only way to do it is if the gateway run H.323.
282
