How to block outgoing calls to specific number?
Hello to all,
I want to block outoging calls to specific number, for example 0644224569. First I tried to apply translation-rule with one rule similar to "rule 1 reject /0644224569/" but this doesn't works, I receive the next message:
Mar 19 11:41:05.239: //-1/3AFC1059806E/RXRULE/regxrule_match: Skipping a call block rule; number=0644224569 rule precedence=1
I searched information about this issue and I deduced that it's not possible to use "rule X reject" with outgoing calls, this only works with incoming calls, it's true?
Also I tried to block number with COR, but here the problem is that the called number match with another dial-peer when the first try is blocked.
Example:
dial-peer cor custom
name local
name international
name movil
name oriol
dial-peer cor list local
member local
dial-peer cor list international
member international
dial-peer cor list movil
member movil
dial-peer cor list administracion
member local
member movil
dial-peer cor list helpdesk
member local
member movil
dial-peer cor list block
member oriol
dial-peer voice 11 voip
corlist outgoing local
description ### SIP Nacionales por VoipBuster por si falla/ocupado ANALOGICA
preference 2
max-conn 4
destination-pattern 0T
progress_ind setup enable 3
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
corlist outgoing international
description ### SIP Internacionales Voipbuster ###
preference 1
max-conn 4
destination-pattern 00T
dtmf-relay rtp-nte
no vad
dial-peer voice 50 pots
corlist outgoing block
description ### FXO ANTENA GSM SALIDA MOVILES ###
translation-profile outgoing SALIDA_CON_6_CELULAR
preference 1
destination-pattern 0644224569
port 0/2/1
ephone-dn  6  dual-line
number 400
pickup-group 830
label David Lopez 400
description David Lopez
name David Lopez
call-forward busy 899
call-forward noan 899 timeout 25
corlist incoming helpdesk
huntstop channel
hold-alert 30 originator
When I call from dn 400 the call is not possible via dial-peer 50, but the call is succes because CME uses dial-peer 11.
any idea?
Thanks!
Chris Deren
Under telephony-settings you can define the following:
after-hours block pattern 1 XXXX 7-24 where XXXX is the digit string you want to block.
HTH,
Chris
Chris Deren
HTH,
Chris
