How-to block premium rate numbers?
I need to block all outgoing premium rate number calls on a CCM - 8.6.2
We already have a Calling Search Space called "blocked_premium_Numbers" which uses a partition called "blocked_Numbers".
Where do I have to look to see which Numbers are specified in this partition?
Thanks in advance :)
Timo
1 ACCEPTED SOLUTION
not quite sure if I
not quite sure if I understood correclty
did you block the numbers you wanted in the route pattern ?
If you want to check , run DNA to see if the number is blocked or not
not quite sure if I
Aaaah! There it is! Thanks :)
76
