How to block SIP caller ID to PSTN?
Sean McQuade
Level 5
Level 5
Hi all,
We have a small office running CME. The customer doesn't want caller ID being presented for calls out the PSTN. For the SCCP phones, we have simply added the "caller-id block" command under the DN and this works. We have a few iPhone users using SIP clients, but can't seem to block the outgoing CLID on this. I did some searching and have tried the clid strip pi-restrict all command, but the calls still present to the PSTN as the main switchboard number. Config below:
voice service voip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
  call service stop
sip
  registrar server expires max 3600 min 120
  no update-callerid
voice register global
mode cme
source-address 192.168.10.1 port 5060
max-dn 10
max-pool 10
load 7971 term71.default
authenticate register
authenticate realm domain.com
timezone 13
hold-alert
mwi stutter
mwi reg-e164
voicemail 200
voice register dn  1
number 205
call-forward b2bua busy 200
call-forward b2bua noan 200 timeout 20
allow watch
name SIP-Office
no-reg
label 205
mwi
voice register pool  1
id mac 0000.0000.0000
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 205 password 1234
codec g711ulaw
no vad
privacy on
Is there any way to achieve this?
Sean
paolo bevilacqua
Are you looking for blocking calling number permanently and for every call ?
Then
dial-peer voice xxx pots
caller-id restrict
for all DPs.
paolo bevilacqua
Then
caller-id restrict
for all DPs.
Thank you Paolo, this worked perfectly.
You're welcome, thank you for the nice rating and good luck!
