Community Member
How to block SIP caller ID to PSTN?
Hi all,
We have a small office running CME. The customer doesn't want caller ID being presented for calls out the PSTN. For the SCCP phones, we have simply added the "caller-id block" command under the DN and this works. We have a few iPhone users using SIP clients, but can't seem to block the outgoing CLID on this. I did some searching and have tried the clid strip pi-restrict all command, but the calls still present to the PSTN as the main switchboard number. Config below:
voice service voip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
  call service stop
sip
  registrar server expires max 3600 min 120
  no update-callerid
voice register global
mode cme
source-address 192.168.10.1 port 5060
max-dn 10
max-pool 10
load 7971 term71.default
authenticate register
authenticate realm domain.com
timezone 13
hold-alert
mwi stutter
mwi reg-e164
voicemail 200
voice register dn  1
number 205
call-forward b2bua busy 200
call-forward b2bua noan 200 timeout 20
allow watch
name SIP-Office
no-reg
label 205
mwi
voice register pool  1
id mac 0000.0000.0000
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 205 password 1234
codec g711ulaw
no vad
privacy on
Is there any way to achieve this?
Sean
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: How to block SIP caller ID to PSTN?
Are you looking for blocking calling number permanently and for every call ?
Then
dial-peer voice xxx pots
caller-id restrict
for all DPs.
Then
caller-id restrict
for all DPs.
Community Member
Thank you Paolo, this worked perfectly.
You're welcome, thank you for the nice rating and good luck!
1596
