How to block specific calling numbers on SIP voice GW?
Hi all,
As per the call flow below, is any way to block specific calling numbers on SIP voice GW or CUCM 7?
( I could see H323 is capable, not sure about SIP voice gateway)
PSTN -> digital T1 ->SIP voice gateway -> Cisco Call Manager -> corporate user
Thanks in advance,
Howard
Re: How to block specific calling numbers on SIP voice GW?
What hardware is running the SIP gateway?  If it is IOS, can you run a TCL script on it, like on an H.323 gateway?
The SIP voice gateway is running on Cisco 2851,IOS 12.4T
I think you can use the TCL script that blocks a list of calling numbers.  It's one of the sample voice TCL scripts over on the Cisco Developer web site.
Hall of Fame Super Gold
How many numbers you need to block ? For less than 15, you can use a translation-rule with to refuse calls under the incoming voip DP.
thanks all for your reply.   Only one phone number I need to block.
I made change to voice gateway, still not working.  I attached the change I made below.    Anything I missed?
voice translation-rule 1
rule 1 reject /XXXXXXX/
voice translation-profile call_block
translate calling 1
dial-peer voice 100 pots
call-block translation-profile incoming call_block
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 0/0/0:23
Howard
Apply the profile as translation-progile, not call-block.
I tried, still doesn't work.
Also, I added the translation profile to voice port, the call still goes through.
voice-port 0/0/0:23
input gain -6
output attenuation 6
Any idea?  Any more information I could gather for troubleshooting?
I run " debug isdn q931" ,   it showed the correct calling number which I want to block,  (  eg.  rule 1 reject /1234567890/ ,    tel#1234567890 is the number I want to block)
Thanks a lot!
652
