How to call the UC from the PSTN
I can't call the UC from the PSTN,but I can call the UC directly by dialing the hunt polit number I set for the UC.
This is the dial-peer I set in gateway,the ip address '142.100.64.13' is my CUCM's address,I changed the ip address to my UC's address,but it still don't work,and the number '1300' is the  hunt polit number for UC.
dial-peer voice 1300 voip
destination-pattern 1300$
session target ipv4:142.100.64.10
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
debug isdn q931 in gateway:
R2#
*Jun  9 08:19:05.234: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0089
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98394
                Exclusive, Channel 20
        Progress Ind i = 0x8583 - Origination address is non-ISDN
        Display i = 'PSTN-HQ-PHONE'
        Calling Party Number i = 0x2180, '4085151111'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '9723031300'
*Jun  9 08:19:05.258: ISDN Se0/3/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8089
*Jun  9 08:19:05.442: ISDN Se0/3/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x8089
*Jun  9 08:19:05.766: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8089
        Cause i = 0x80AF - Resource unavailable, unspecified
*Jun  9 08:19:05.786: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0089
*Jun  9 08:19:05.790: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8089
R2#
debug cch323 h225 in gateway
R2#
*Jun  9 08:19:41.486: //20/A3D0DDAC800B/H323/run_h225_sm: Received event H225_EV_SETUP while at state H225_IDLE
*Jun  9 08:19:41.486: //20/A3D0DDAC800B/H323/check_qos_and_send_setup: Setup ccb 0x488622B0
*Jun  9 08:19:41.486: //20/A3D0DDAC800B/H323/run_h225_sm: Received event H225_EV_FS_SETUP while at state H225_IDLE
*Jun  9 08:19:41.486: //20/A3D0DDAC800B/H323/idle_fsSetup_hdlr: Setup ccb 0x488622B0
*Jun  9 08:19:41.486: //20/A3D0DDAC800B/H323/generic_send_setup:
generic_send_setup: is_overlap = 0, info_complete = 0
*Jun  9 08:19:41.486: //20/A3D0DDAC800B/H323/generic_send_setup: sending calling IE
*Jun  9 08:19:41.486: //20/A3D0DDAC800B/H323/generic_send_setup: ====== PI = 3
*Jun  9 08:19:41.486: //20/A3D0DDAC800B/H323/generic_send_setup: Send infoXCap=128, infoXRate=16, rateMult=0, xMode=128, info_layer1_prot=163
*Jun  9 08:19:41.486: //20/A3D0DDAC800B/H323/generic_send_setup: src address = 10.1.1.2; dest address = 142.100.64.10
*Jun  9 08:19:41.490: //20/A3D0DDAC800B/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_REQ_FS_SETUP state
*Jun  9 08:19:41.638: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type CALLPROCIND_CHOSEN
*Jun  9 08:19:41.638: //20/A3D0DDAC800B/H323/callproc_ind: ====== PI = 0
*Jun  9 08:19:41.638: //20/A3D0DDAC800B/H323/callproc_ind: Call Manager detected
*Jun  9 08:19:41.638: //20/A3D0DDAC800B/H323/cch323_h225_receiver: CALLPROCIND_CHOSEN: src address = 10.1.1.2; dest address = 142.100.64.10
*Jun  9 08:19:41.638: //20/A3D0DDAC800B/H323/run_h225_sm: Received event H225_EV_CALLPROC_IND while at state H225_REQ_FS_SETUP
*Jun  9 08:19:41.638: //20/A3D0DDAC800B/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_SETUP state to H225_REQ_FS_CALLPROC state
*Jun  9 08:19:41.650: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type ALERTIND_CHOSEN
*Jun  9 08:19:41.650: //20/A3D0DDAC800B/H323/alert_ind: ====== PI = 0
*Jun  9 08:19:41.650: //20/A3D0DDAC800B/H323/alert_ind: alert ind ie_bit_mask 0x1260, displayInfo
*Jun  9 08:19:41.650: //20/A3D0DDAC800B/H323/alert_ind: delay H245 address in alert
*Jun  9 08:19:41.650: //20/A3D0DDAC800B/H323/alert_ind: Call Manager detected
*Jun  9 08:19:41.650: //20/A3D0DDAC800B/H323/cch323_h225_receiver: ALERTIND_CHOSEN: src address = 10.1.1.2; dest address = 142.100.64.10
*Jun  9 08:19:41.650: //20/A3D0DDAC800B/H323/run_h225_sm: Received event H225_EV_ALERT_IND while at state H225_REQ_FS_CALLPROC
*Jun  9 08:19:41.650: //20/A3D0DDAC800B/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_CALLPROC state to H225_REQ_FS_ALERT state
*Jun  9 08:19:41.890: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type NOTIFYIND_CHOSEN
*Jun  9 08:19:41.890: //20/A3D0DDAC800B/H323/notify_ind: Rcvd NOTIFY Notification Indicator IE = 113
*Jun  9 08:19:41.890: //20/A3D0DDAC800B/H323/notify_ind: Rcvd NOTIFY Connected Number as IE
*Jun  9 08:19:41.890: //20/A3D0DDAC800B/H323/notify_ind: [cnum]/[oct]/[oct3a]= [1300]/[0x20]/[0x81]
*Jun  9 08:19:41.890: //20/A3D0DDAC800B/H323/notify_ind: Notify data embedded, mask=0x00000005
*Jun  9 08:19:41.890: //20/A3D0DDAC800B/H323/cch323_h225_receiver: NOTIFYIND_CHOSEN: src address = 10.1.1.2; dest address = 142.100.64.10
*Jun  9 08:19:41.890: //20/A3D0DDAC800B/H323/run_h225_sm: Received event H225_EV_NOTIFY_IND while at state H225_REQ_FS_ALERT
*Jun  9 08:19:41.890: //20/A3D0DDAC800B/H323/notify_msg_notify: Notify data found, mask=0x00000005
*Jun  9 08:19:41.890: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type SETUPCFM_CHOSEN
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/setup_cfm_ind: ====== PI = 0
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/setup_cfm_ind: Set new event H225_EV_SETUP_CFM_IND
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/setup_cfm_ind: Rcvd CONNECT Display Info IE = VoiceMail
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/setup_cfm_ind: Call Manager detected
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/cch323_h225_receiver: SETUPCFM_CHOSEN: src address = 10.1.1.2; dest address = 142.100.64.10
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/run_h225_sm: Received event H225_EV_SETUP_CFM_IND while at state H225_REQ_FS_ALERT
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/setup_cfm_notify: status = 48000009
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_ALERT state to H225_WAIT_FOR_H245 state
*Jun  9 08:19:41.894: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type NOTIFYIND_CHOSEN
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/defer_indication: Called while at state H225_WAIT_FOR_H245
*Jun  9 08:19:41.894: //20/A3D0DDAC800B/H323/cch323_h225_receiver: NOTIFYIND_CHOSEN: src address = 10.1.1.2; dest address = 142.100.64.10
*Jun  9 08:19:41.966: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type RELEASEIND_CHOSEN
*Jun  9 08:19:41.966: //20/A3D0DDAC800B/H323/release_ind: Disconnect cause 47 location code 0
*Jun  9 08:19:41.966: //20/A3D0DDAC800B/H323/cch323_h225_receiver: RELEASEIND_CHOSEN: src address = 10.1.1.2; dest address = 142.100.64.10
*Jun  9 08:19:41.966: //20/A3D0DDAC800B/H323/run_h225_sm: Received event H225_EV_RELEASE_IND while at state H225_WAIT_FOR_H245
*Jun  9 08:19:41.970: //20/A3D0DDAC800B/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_WAIT_FOR_H245
*Jun  9 08:19:41.970: //20/A3D0DDAC800B/H323/cch323_h225_send_release: Cause = 47; Location = 0
*Jun  9 08:19:41.970: //20/A3D0DDAC800B/H323/cch323_h225_send_release: h225TerminateRequest: src address = 167837954; dest address = 142.100.64.10
*Jun  9 08:19:41.970: //20/A3D0DDAC800B/H323/cch323_h225_set_new_state: Changing from H225_WAIT_FOR_H245 state to H225_IDLE state
R2#
R2#
Bronze
By UC you mean Unity
By UC you mean Unity connection right?
I have always configured it to come in via CUCM. Maybe check the inbound CSS on your gateway configuration to ensure it has access to the partition that contains your hunt pilot?
I found the reason,from CUCM
I found the reason,from CUCM 9.1 there is a new command in region,which is maximum audio bit rate,
even you have a transcoder the maximum audio bit rate can stop your calls.
72
