Community Member
how-to callforward-all on a h323 dial-peer, cme?
Hi there,
I have a cme with several ATAs-186 as fax gateway (hs323) configured.
How can I do a callforward-all on these numbers. External incoming calls can be done throught a translation-rule but how can I forward internal calls? With a incoming-translation rule on the dial-peer?
Outgoing calls must still working on the ATA/dial-peer.
Norbert
1 ACCEPTED SOLUTION
VIP Super Bronze
Is the ATA registered as an ephone with an ephone-dn on it? If yes then you can use 'call-forward all target-number' on the phone-dn.
If you have the ATA using an H.323 image you would need the incoming translation-rule/profile applied to the incoming PSTN dial-peer, not the outgoing ATA dial-peer. You need to make IOS chose a different outgoing dial-peer.
Please remember to rate helpful responses and identify helpful or correct answers.
1 REPLY
VIP Super Bronze
106
