Community Member
how to change cucm gui language to default?
           I have installed cucm locale file,so the gui language have change,also I have changed the phone interface language,but now i want to change cucm gui language to default languge(english),but also keep the phone interface in localized language.How can I do this?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Change the language from the
Change the language from the browser you're using.
java
if this helps, please rate
www.cisco.com/go/pdi
java
I am guessing you are looking
I am guessing you are looking for User Management -> End User -> Select the user and change the Locale there. If not, please explain what else you are looking for.
Please rate useful posts.
Community Member
I wanna change the cucm
I wanna change the cucm administration gui to default language(english),not phone or user specific language,how can i do this?
Community Member
I had the same issue on
I had the same issue on another version. The workaound was just to ajust the admin web browser locale to english on first position.
157
