tka
How to change Extension Mobility PIN and password from the Phone
Hi all,
How could we change Extension Mobility PIN number and Passwords from the phone? Is there any config on CCm to do?
1 ACCEPTED SOLUTION
Re: How to change Extension Mobility PIN and password from the P
You can't do it from the phone, you would need to create a whole custom script to do that. You can do it from CCMUser or CCMadmin which are the ways we provide
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
218
