How to change IP phone from static IP to DHCP
Hello all,
We are in the middle of a CallManager migration from v4.3 to v8.5. Our plan to switch phones from old system to new was to modify DHCP settings.
We have realized most of the IP phones have static IPs configured.
Do you know of an easy way to bulk change this setting in all phones registered in the old system?
Thanks in advance and best regards,
Alfonso Hidalgo
Hall of Fame Super Silver
There is no easy bulk way to do this centrally as the configuration is done at the phone level, your only option would be to script some kind of button push application, sorry.
HTH,
Chris
Isn't there any way to upload an XML file with the config setting change to DHCP?
Upload it to the phones?  Never heard of it, perhaps others have.
HTH,
Chris
636
