How to change MOH audio source without resetting devices
Hello All,
Does anyone know if there is a way to change the MOH audio source on the fly without having to reset devices ?
I am running CCM 4.1.3 sr6a.
Thanks in advance and I appreciate any inputs / Suggestions !!!
Danny
Re: How to change MOH audio source without resetting devices
unfortunately changes that ask you to reset the devices are because a config file has changed and they do not download the files unless they go thru the reset process
it's not just because, you need to reset the devices as instructed
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks Jaime !! Appreciate your response !!!
Danny
139
