How to change OS pass for CUCM version 9 in VMware
How can we change the OS pass for cucm running into vmware?
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
1 ACCEPTED SOLUTION
Re: How to change OS pass for CUCM version 9 in VMware
Yes you can use external dvd.. Infact if you login to VMWARE client from your PC and your PC has DVD drive, you can use PC dvd drive as well by connecting(mapping) to vmware..
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
VIP Purple
Hi ,
CLI of CUCM 9 says u can use command but does not appear utils reset_ui_administrator_password
u can try with set password user admin command and check.
regds,
aman
To add little more to Aman's post.
utils reset_ui_administrator_password - to reset application user password.
set password admin - OS admin password
But we dont know the old OS pass
VIP Purple
this means u want to reset the password. Do not want to change password.
follow the link provided by Prasad.
regds,
aman
It was my mistake , yes reset not change the OS pass
But my question was related for CUCM into VMware
We can proceed with external dvd .Is that possible,?The server is UCS
Br,
Nadeem
Thank you All
chrysostomos
169
