How to Change "Private" in blocked CLID to Something else like "Blocked"
I recently setup a CUCM 7.x PBX for a hotel in my location.  The Customer wanted all calls from Hotel Room to Hotel Room and from Hotel Room to Courtesy phones to block the caller id from the displays.
I followed the "Display Restrictions" section Of the CUCM Administration guide.  The solution worked perfectly.  However, when CLID is restricted on the translation pattern the phone displays "To Private" and "From Private".  The customer would like to change the word "Private" to  "Blocked" or "Restricted".
Anybody know if this can be done?
Any help would be greatly appreciated.
Dave
Everyone's tags (5)
1 REPLY
Re: How to Change "Private" in blocked CLID to Something else li
Unfortunately that' not something you can change
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
232
